Aller au contenu principal
Thrustmaster T Flight Hotas 4 Trigger Replacement
Ce dont vous avez besoin
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: étape 1, image 1 de 2 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: étape 1, image 2 de 2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: étape 2, image 1 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: étape 2, image 2 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: étape 2, image 3 de 3
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: étape 3, image 1 de 1
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: étape 4, image 1 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: étape 4, image 2 de 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: étape 4, image 3 de 3
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
Aaron Banaga
Membre depuis le 09/11/17
526 Réputation
4 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 3,257
