Aller au contenu principal
TiVo Premiere XL4 Power Supply Replacement
Ce dont vous avez besoin
  1. TiVo Premiere XL4 Power Supply Replacement, Case: étape 1, image 1 de 1
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. TiVo Premiere XL4 Power Supply Replacement: étape 2, image 1 de 2 TiVo Premiere XL4 Power Supply Replacement: étape 2, image 2 de 2
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. TiVo Premiere XL4 Power Supply Replacement: étape 3, image 1 de 1
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
  4. TiVo Premiere XL4 Power Supply Replacement, Power Supply: étape 4, image 1 de 1
    • Remove the 140 mm T8 screw from the back of the TiVo premiere XL4 box holding the power supply in place using a Torx screwdriver.
  5. TiVo Premiere XL4 Power Supply Replacement: étape 5, image 1 de 1
    • Remove the two 80 mm T10 screws from the power supply using a Torx screwdriver.
  6. TiVo Premiere XL4 Power Supply Replacement: étape 6, image 1 de 1
    • Remove the power cable from the motherboard by gently pinching the connector.
  7. TiVo Premiere XL4 Power Supply Replacement: étape 7, image 1 de 1
    • Pinch the two plastic plugs and lift the power supply to detach the plugs from the board.
  8. TiVo Premiere XL4 Power Supply Replacement: étape 8, image 1 de 1
    • Take out the power supply unit.
Frances Prewitt
Membre depuis le 10/22/18
661 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S1-G1, Williams Fall 2018 Membre de l'équipe Baylor, Team S1-G1, Williams Fall 2018
BU-WILLIAMS-F18S1G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 7
Total : 395
