Aller au contenu principal
Introduction
The battery acts as an internal power source for the device. In case this battery needs to be replaced, this simple guide will walk you through the steps of removing the current battery to replace it.
Pièces
Aucune pièce spécifiée.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  5. Locate the battery on the motherboard.
    • Locate the battery on the motherboard.
  6. Using the spudger, wedge the metal clip off of the top surface of the battery.
    • Using the spudger, wedge the metal clip off of the top surface of the battery.
  7. Use your finger to push the battery sideways out of its holder.
    • Use your finger to push the battery sideways out of its holder.
Cody Hunter
Membre depuis le 10/10/2011
22 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-33, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 5
Total : 1,378
