Aller au contenu principal
TiVo Series 2 TCD24008A Motherboard Replacement
Ce dont vous avez besoin
  1. TiVo Series 2 TCD24008A Motherboard Replacement, Cover: étape 1, image 1 de 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Motherboard Replacement: étape 2, image 1 de 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Motherboard Replacement: étape 3, image 1 de 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the two 0.59 inch T-8 size screws on the back panel
  5. TiVo Series 2 TCD24008A Motherboard Replacement: étape 5, image 1 de 1
    • Unplug the fan from the motherboard by gently pulling up on the red plug.
  6. TiVo Series 2 TCD24008A Motherboard Replacement: étape 6, image 1 de 1
    • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  7. TiVo Series 2 TCD24008A Motherboard Replacement: étape 7, image 1 de 1
    • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  8. TiVo Series 2 TCD24008A Motherboard Replacement: étape 8, image 1 de 1
    • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  9. TiVo Series 2 TCD24008A Motherboard Replacement: étape 9, image 1 de 2 TiVo Series 2 TCD24008A Motherboard Replacement: étape 9, image 2 de 2
    • Locate the four metal tabs on the motherboard.
    • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
  10. TiVo Series 2 TCD24008A Motherboard Replacement: étape 10, image 1 de 1
    • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  11. TiVo Series 2 TCD24008A Motherboard Replacement: étape 11, image 1 de 2 TiVo Series 2 TCD24008A Motherboard Replacement: étape 11, image 2 de 2
    • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
    • Pull up and away from the back panel so all of the cable inputs slip through the casing.
Cody Hunter
Membre depuis le 10/10/11
22 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-33, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,078
