Aller au contenu principal
TiVo Series 2 TCD540080 Motherboard Replacement
Ce dont vous avez besoin
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: étape 1, image 1 de 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: étape 3, image 1 de 2 TiVo Series 2 TCD540080 Motherboard Replacement: étape 3, image 2 de 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: étape 5, image 1 de 1
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: étape 6, image 1 de 1
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: étape 7, image 1 de 1
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: étape 8, image 1 de 1
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: étape 9, image 1 de 1
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: étape 10, image 1 de 3 TiVo Series 2 TCD540080 Motherboard Replacement: étape 10, image 2 de 3 TiVo Series 2 TCD540080 Motherboard Replacement: étape 10, image 3 de 3
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: étape 11, image 1 de 1
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
Svyatoslav Markeyev
Membre depuis le 04/16/10
135 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 33-79, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 12
Total : 4,423
