Aller au contenu principal
TicWatch Pro 3 GPS Battery Replacement
Ce dont vous avez besoin
  1. TicWatch Pro 3 GPS Battery Replacement, Power down your watch: étape 1, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Power down your watch: étape 1, image 2 de 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. TicWatch Pro 3 GPS Battery Replacement, Unfasten the back cover: étape 2, image 1 de 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. TicWatch Pro 3 GPS Battery Replacement, Loosen the back cover adhesive: étape 3, image 1 de 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  4. TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: étape 4, image 1 de 3 TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: étape 4, image 2 de 3 TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: étape 4, image 3 de 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
  5. TicWatch Pro 3 GPS Battery Replacement, Disconnect the sensor assembly cable: étape 5, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the sensor assembly cable: étape 5, image 2 de 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  6. TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: étape 6, image 1 de 3 TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: étape 6, image 2 de 3 TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: étape 6, image 3 de 3
    • Remove the back cover assembly.
  7. TicWatch Pro 3 GPS Battery Replacement, Disconnect the microphone cable: étape 7, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the microphone cable: étape 7, image 2 de 2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
  8. TicWatch Pro 3 GPS Battery Replacement, Unfasten the core assembly: étape 8, image 1 de 1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
  9. TicWatch Pro 3 GPS Battery Replacement, Pry up the core assembly: étape 9, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the core assembly: étape 9, image 2 de 2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
  10. TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: étape 10, image 1 de 3 TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: étape 10, image 2 de 3 TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: étape 10, image 3 de 3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
  11. TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: étape 11, image 1 de 3 TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: étape 11, image 2 de 3 TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: étape 11, image 3 de 3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
  12. TicWatch Pro 3 GPS Battery Replacement, Remove the core assembly: étape 12, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Remove the core assembly: étape 12, image 2 de 2
    • Remove the core assembly.
  13. TicWatch Pro 3 GPS Battery Replacement, Disconnect the interconnect cable: étape 13, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the interconnect cable: étape 13, image 2 de 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  14. TicWatch Pro 3 GPS Battery Replacement, Remove the daughterboard: étape 14, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Remove the daughterboard: étape 14, image 2 de 2
    • Use a pair of tweezers to remove the daughterboard.
  15. TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: étape 15, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: étape 15, image 2 de 2
    • The battery is held in place by mild adhesive.
    • Insert the flat end of a spudger between the bottom edge of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Pry upwards to loosen the battery.
    • If you're struggling to pry up the battery, place a heated iOpener onto the motherboard to loosen the adhesive underneath. Don't apply the iOpener directly onto the battery.
    • Don't try to remove the battery all the way yet. It's still connected to the motherboard.
  16. TicWatch Pro 3 GPS Battery Replacement, Reposition the battery: étape 16, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Reposition the battery: étape 16, image 2 de 2
    • Carefully fold the battery over to gain access to the battery cable connector.
    • Avoid straining or tearing the battery cable.
  17. TicWatch Pro 3 GPS Battery Replacement, Disconnect the battery: étape 17, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the battery: étape 17, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  18. TicWatch Pro 3 GPS Battery Replacement, Remove the battery: étape 18, image 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Remove the battery: étape 18, image 2 de 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
16 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
203 250 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
13 commentaires
Where did you buy a replacement battery (if you did)? I have scoured thru aliexpress, ebay, and tried to find shattered-screen watches I could transplant from, with no luck so far. I guess I'll keep looking. My watch barely lasted a year before the battery life halved. The voltage sag is so bad the watch bootloops whenever it vibrates below 30% voltage.
George - Réponse
I've found a listing in aliexpress for an aftermarket battery but need to de-solder the original BMS and transfer to this new battery. Here's the link to aliexpress.
https://www.aliexpress.com/item/10050049...
Daniel Lee - Réponse
I don't think it's tin welding, but most likely TIG welding.
Difficult to open it, but the less experienced could solder the battery contacts on the top without opening the old solder.
https://imgur.com/zhFXcQ4
https://imgur.com/cKJb137
marco deirossi - Réponse
A small problem (solved) that I encountered with the battery purchased as compatible from ali-express is the greater ( >5mm)
distance (compared to the battery) of the original two poles of the battery.
You have to bend them carefully inwards to be able to weld them afterwards.
https://imgur.com/5mrfzDk
https://imgur.com/v2OCVCc
https://imgur.com/Izw3dU1
https://imgur.com/QsnAN6I
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 50
7 derniers jours : 265
30 derniers jours : 1,126
Total : 13,686
