Aller au contenu principal
Timex T132 "iMac" Alarm Clock Battery Replacement
Ce dont vous avez besoin
  1. Timex T132 "iMac" Alarm Clock Battery Replacement, Battery: étape 1, image 1 de 1
    • To prevent any injury, unplug the power cord from the outlet so the device is powered off.
    • Hold the clock so it is upside down. You should be able to view its caution labels.
    • Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
    • Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
  2. Timex T132 "iMac" Alarm Clock Battery Replacement: étape 2, image 1 de 3 Timex T132 "iMac" Alarm Clock Battery Replacement: étape 2, image 2 de 3 Timex T132 "iMac" Alarm Clock Battery Replacement: étape 2, image 3 de 3
    • Rotate the device so the clock's display is facing away from you.
    • Use the flat end of the spudger to pry out the battery.
    • Once fully lifted, grab the end of the battery and pull out the rest of the battery.
    • Do not remove the battery all the way because it is still connected. Doing so may result in damaging the power wires.
  3. Timex T132 "iMac" Alarm Clock Battery Replacement: étape 3, image 1 de 1
    • Place the clock upside down on a flat surface.
    • Because the device is irregularly shaped, you may have to manually or externally balance it.
    • Grab the blue connector covering tab near the power wires and peel the snap connector off the battery terminals to disconnect it.
    • Do not pull out the snap connector and its wires because it is still connected to the device. Doing so may result in damaging the power wires.
    • Remove the battery.
Tyler Price
Membre depuis le 04/07/14
1 038 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 6-2, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 371
