Introduction
The Tineco FLOOR ONE S3 Breeze (model no. FW007600US) will sometimes have problems with the wheels wearing out over time, and it may need to be replaced by removing the wheel cover plate and removing the existing wheels. After a quick reassembly the machine is ready to operate. This replacement guide contains the following steps for the wheels replacement.
The wheels are what allows the vacuum to move and clean efficiently. If the wheels are broken, then the vacuum is just about useless.
Ce dont vous avez besoin
Place a finger on the lever located on the brush roller cover.
Firmly push the lever with a finger to remove the brush roller cover.
Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
Remove the first plastic cover.
