Aller au contenu principal
Toaster Oven Toasting Knob Replacement
Ce dont vous avez besoin
  1. Toaster Oven Toasting Knob Replacement, Toasting knob: étape 1, image 1 de 3 Toaster Oven Toasting Knob Replacement, Toasting knob: étape 1, image 2 de 3 Toaster Oven Toasting Knob Replacement, Toasting knob: étape 1, image 3 de 3
    • Remove the two 4mm by 8mm screws from the back of the toaster oven.
  2. Toaster Oven Toasting Knob Replacement: étape 2, image 1 de 3 Toaster Oven Toasting Knob Replacement: étape 2, image 2 de 3 Toaster Oven Toasting Knob Replacement: étape 2, image 3 de 3
    • Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
    • Take the two supports off of the bottom.
  3. Toaster Oven Toasting Knob Replacement: étape 3, image 1 de 2 Toaster Oven Toasting Knob Replacement: étape 3, image 2 de 2
    • Remove the two 4mm by 4mm screws from the base in order to remove the tray.
  4. Toaster Oven Toasting Knob Replacement: étape 4, image 1 de 1
    • Slide the back panel off of the oven.
  5. Toaster Oven Toasting Knob Replacement: étape 5, image 1 de 1
    • Grip the sides of the metal cover and lift the cover up off the toaster oven top.
  6. Toaster Oven Toasting Knob Replacement: étape 6, image 1 de 3 Toaster Oven Toasting Knob Replacement: étape 6, image 2 de 3 Toaster Oven Toasting Knob Replacement: étape 6, image 3 de 3
    • The knob is missing in the first picture.
    • Push the knob into the hole.
    • The knob is now back in place in the last picture.
Alissa Mell
Membre depuis le 09/26/17
101 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team S5-G25, Galliah Fall 2017 Membre de l'équipe Michigan Tech, Team S5-G25, Galliah Fall 2017
MTU-GALLIAH-F17S5G25
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 1,892
