Aller au contenu principal
Toilet Seat Replacement
Ce dont vous avez besoin
  1. Toilet Seat Replacement, Toilet Seat: étape 1, image 1 de 1
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: étape 2, image 1 de 2 Toilet Seat Replacement: étape 2, image 2 de 2
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: étape 3, image 1 de 3 Toilet Seat Replacement: étape 3, image 2 de 3 Toilet Seat Replacement: étape 3, image 3 de 3
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: étape 4, image 1 de 2 Toilet Seat Replacement: étape 4, image 2 de 2
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: étape 5, image 1 de 1
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: étape 6, image 1 de 1
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
To re-install your previous seat, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Christopher Carter
Membre depuis le 02/24/15
231 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-5, Green Winter 2015 Membre de l'équipe Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 16
Total : 1,963
