Aller au contenu principal
Toilet Tank Assembly Replacement
Ce dont vous avez besoin
  1. Toilet Tank Assembly Replacement, Tank Lid: étape 1, image 1 de 3 Toilet Tank Assembly Replacement, Tank Lid: étape 1, image 2 de 3 Toilet Tank Assembly Replacement, Tank Lid: étape 1, image 3 de 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: étape 2, image 1 de 2 Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: étape 2, image 2 de 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: étape 3, image 1 de 2 Toilet Tank Assembly Replacement, Draining a Toilet Tank: étape 3, image 2 de 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: étape 4, image 1 de 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: étape 4, image 2 de 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: étape 4, image 3 de 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  5. Toilet Tank Assembly Replacement, Supply Tube: étape 5, image 1 de 3 Toilet Tank Assembly Replacement, Supply Tube: étape 5, image 2 de 3 Toilet Tank Assembly Replacement, Supply Tube: étape 5, image 3 de 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  6. Toilet Tank Assembly Replacement, Tank Assembly: étape 6, image 1 de 3 Toilet Tank Assembly Replacement, Tank Assembly: étape 6, image 2 de 3 Toilet Tank Assembly Replacement, Tank Assembly: étape 6, image 3 de 3
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
  7. Toilet Tank Assembly Replacement: étape 7, image 1 de 2 Toilet Tank Assembly Replacement: étape 7, image 2 de 2
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
11 autres ont terminé cette réparation.
Ron Davis
Membre depuis le 02/17/15
31 204 Réputation
13 tutoriels rédigés
3 commentaires
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - Réponse
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - Réponse
Thank you for the info.
DonnaRHellman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 39
30 derniers jours : 202
Total : 12,831
