Introduction
Is your massage gun not changing speed settings? This guide explains how to remove and replace the small motherboard located under the top cover plate. For this repair you will need a black spudger and phillips #00 screwdriver.
Ce dont vous avez besoin
Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic and use the tip of the spudger to pry the rubber out.
