Aller au contenu principal
TomTom GO Live 1535M Speaker Replacement
Ce dont vous avez besoin
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: étape 1, image 1 de 1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: étape 2, image 1 de 2 TomTom GO Live 1535M Speaker Replacement: étape 2, image 2 de 2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: étape 3, image 1 de 1
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: étape 4, image 1 de 1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Simply lift the speaker up and out of the base to replace it.
Mathias Sagide
Membre depuis le 01/20/15
618 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 19-4, Blackwell Spring 2014 Membre de l'équipe USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 membre
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 247
