Aller au contenu principal
TomTom One XL Battery Replacement
Ce dont vous avez besoin
  1. TomTom One XL Battery Replacement, Back Panel: étape 1, image 1 de 2 TomTom One XL Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: étape 2, image 1 de 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: étape 3, image 1 de 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: étape 4, image 1 de 2 TomTom One XL Battery Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: étape 5, image 1 de 1
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: étape 6, image 1 de 3 TomTom One XL Battery Replacement: étape 6, image 2 de 3 TomTom One XL Battery Replacement: étape 6, image 3 de 3
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: étape 7, image 1 de 3 TomTom One XL Battery Replacement: étape 7, image 2 de 3 TomTom One XL Battery Replacement: étape 7, image 3 de 3
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: étape 8, image 1 de 3 TomTom One XL Battery Replacement: étape 8, image 2 de 3 TomTom One XL Battery Replacement: étape 8, image 3 de 3
    • Reconnect the battery ribbon cable to its port.
DeVhan
Membre depuis le 03/11/15
401 Réputation
4 tutoriels rédigés
Équipe
Colorado Springs, Team 9-6, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 9-6, Panko Spring 2015
UCCS-PANKO-S15S9G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 1,465
