Aller au contenu principal
Tonneau Trifold Bed Cover Retention Pin Replacement
Ce dont vous avez besoin
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: étape 1, image 1 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: étape 1, image 2 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: étape 1, image 3 de 3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: étape 2, image 1 de 2 Tonneau Trifold Bed Cover Retention Pin Replacement: étape 2, image 2 de 2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: étape 3, image 1 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: étape 3, image 2 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: étape 3, image 3 de 3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: étape 4, image 1 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: étape 4, image 2 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: étape 4, image 3 de 3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: étape 5, image 1 de 2 Tonneau Trifold Bed Cover Retention Pin Replacement: étape 5, image 2 de 2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
To reassemble your device, follow these instructions in order.
Christopher King
Membre depuis le 01/16/18
139 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 membres
26 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 746
