Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Toptro TR23 Motherboard Replacement
Ce dont vous avez besoin
  1. Toptro TR23 Motherboard Replacement, Case: étape 1, image 1 de 3 Toptro TR23 Motherboard Replacement, Case: étape 1, image 2 de 3 Toptro TR23 Motherboard Replacement, Case: étape 1, image 3 de 3
    • Set the projector on its side so the the front is facing to your left.
    • Insert an opening tool into the seam between the black chassis and the silver case.
    • Pry around the perimeter until the case fully releases.
    • When removing the cover, be careful as there is an internal connector attached to the lid and the projectors motherboard. You’ll have to carefully detach that before fully removing the projector case.
    • Remove the case.
  2. Toptro TR23 Motherboard Replacement, Motherboard: étape 2, image 1 de 3 Toptro TR23 Motherboard Replacement, Motherboard: étape 2, image 2 de 3 Toptro TR23 Motherboard Replacement, Motherboard: étape 2, image 3 de 3
    • Use your fingernails to gently disconnect the six sliding connectors from their motherboard sockets.
    • Gently lift the two antenna cable connector to disconnect them.
  3. Toptro TR23 Motherboard Replacement: étape 3, image 1 de 3 Toptro TR23 Motherboard Replacement: étape 3, image 2 de 3 Toptro TR23 Motherboard Replacement: étape 3, image 3 de 3
    • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
    • Using your fingers carefully disconnect the ribbon cable.
  4. Toptro TR23 Motherboard Replacement: étape 4, image 1 de 3 Toptro TR23 Motherboard Replacement: étape 4, image 2 de 3 Toptro TR23 Motherboard Replacement: étape 4, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the four 7.3 mm screws securing the motherboard to the projector.
  5. Toptro TR23 Motherboard Replacement: étape 5, image 1 de 3 Toptro TR23 Motherboard Replacement: étape 5, image 2 de 3 Toptro TR23 Motherboard Replacement: étape 5, image 3 de 3
    • Gently lift the motherboard off to the left, with care not to strain the single remaining attached cable.
    • Disconnect the last connector from its motherboard scoket.
    • Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
evry1luvsj_
Membre depuis le 08/28/24
193 Réputation
2 tutoriels rédigés
Équipe
1 commentaire de tutoriel
Where can I buy a motherboard for it?
Joseph Nemeth - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 235
