Aller au contenu principal
Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement
Ce dont vous avez besoin
  1. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Disconnect the spark plug wire: étape 1, image 1 de 2 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Disconnect the spark plug wire: étape 1, image 2 de 2
    • Before you begin, ensure that the mower is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Chock the rear wheels: étape 2, image 1 de 1
    • Chock the rear wheels to prevent the mower from rolling during service.
    • If the blades are extremely dirty, you can clean them using the washout fitting so the bolts on the underside of the blade guard are accessible.
  3. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Lift up the deflector: étape 3, image 1 de 2 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Lift up the deflector: étape 3, image 2 de 2
    • Lift up the plastic deflector.
  4. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the grass bag: étape 4, image 1 de 3 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the grass bag: étape 4, image 2 de 3 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the grass bag: étape 4, image 3 de 3
    • While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
    • Remove the grass bag.
  5. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Tilt the mower on its side: étape 5, image 1 de 1
    • Tilt the mower onto its side so the blades are facing out.
    • This may require two people.
  6. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the blade bolt: étape 6, image 1 de 2 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the blade bolt: étape 6, image 2 de 2
    • Use an impact driver with a 5/8-inch socket to remove the left blade bolt.
    • If necessary, brace the blade with a screwdriver or extension by placing it in the hole in the metal blade guard.
  7. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the blade: étape 7, image 1 de 2 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the blade: étape 7, image 2 de 2
  8. Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the blade key adapter: étape 8, image 1 de 2 Toro Walk Behind Mowers 21199HD 2018 Left Blade Replacement, Remove the blade key adapter: étape 8, image 2 de 2
    • Remove the left blade key adapter.
Carsten Frauenheim
Membre depuis le 03/10/20
114 581 Réputation
339 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 299 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 330
