Aller au contenu principal
Torque King Electric RTR RC Monster Truck Antenna Replacement
Ce dont vous avez besoin
  1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: étape 1, image 1 de 2 Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: étape 1, image 2 de 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Antenna Replacement: étape 2, image 1 de 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Antenna Replacement, Loosen Screw: étape 3, image 1 de 1
    • Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
    • The wire that connects the antenna to the circuitry of the truck might be blocking the screw. Take care when moving the wire out of the way not to pull it from its soldering.
  4. Torque King Electric RTR RC Monster Truck Antenna Replacement, Remove Antenna: étape 4, image 1 de 1
    • Carefully slide the antenna out from under the screw and remove.
Colton Sholtis
Membre depuis le 01/30/15
257 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-30, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 524
