Aller au contenu principal
Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement
Ce dont vous avez besoin
  1. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: étape 1, image 1 de 2 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: étape 1, image 2 de 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: étape 2, image 1 de 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing Screws: étape 3, image 1 de 1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing the Wheel: étape 4, image 1 de 1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Rear Wheel Suspension: étape 5, image 1 de 1
    • After removing the rear wheels, remove the 8mm screw under each spring with a Phillips 1 screwdriver.
  6. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: étape 6, image 1 de 1
    • Slide off the bottom part of the rod connected to the chassis.
  7. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: étape 7, image 1 de 3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: étape 7, image 2 de 3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: étape 7, image 3 de 3
    • Pull the black washer inside the spring downwards and towards the truck's rear simultaneously in order to remove the suspension.
Colton Sholtis
Membre depuis le 01/30/15
257 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-30, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 195
