Introduction
The suspension of the truck is responsible for its steering stability and ability to drive over rough terrain. Through regular use, the springs and rods of the suspension may become damaged; this is a guide to replace those parts.
Ce dont vous avez besoin
From the top view, remove each of the four pins that hold the casing in place.
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
After removing the rear wheels, remove the 8mm screw under each spring with a Phillips 1 screwdriver.
