Introduction
Check to see if anything is obstructing the wheel before referring to this guide.
Ce dont vous avez besoin
From the top view, remove each of the four pins that hold the casing in place.
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
