Aller au contenu principal
Toshiba A1304T Logic Board Replacement
Ce dont vous avez besoin
  1. Toshiba A1304T Logic Board Replacement, Back panel: étape 1, image 1 de 1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Logic Board Replacement: étape 2, image 1 de 1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Logic Board Replacement: étape 3, image 1 de 2 Toshiba A1304T Logic Board Replacement: étape 3, image 2 de 2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Logic Board Replacement, Logic Board: étape 4, image 1 de 3 Toshiba A1304T Logic Board Replacement, Logic Board: étape 4, image 2 de 3 Toshiba A1304T Logic Board Replacement, Logic Board: étape 4, image 3 de 3
    • Use your fingers to gently detach the ribbon wire from the logic board.
  5. Toshiba A1304T Logic Board Replacement: étape 5, image 1 de 2 Toshiba A1304T Logic Board Replacement: étape 5, image 2 de 2
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
  6. Toshiba A1304T Logic Board Replacement: étape 6, image 1 de 2 Toshiba A1304T Logic Board Replacement: étape 6, image 2 de 2
    • Use your thumb to peel the keypad from the device.
Christopher
Membre depuis le 04/22/10
90 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 16-6, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 2,596
