Aller au contenu principal
Introduction
Removing the back may be the easiest thing to do, however do not forget about the screws hidden under the rubber foot pads!
Pièces
Aucune pièce spécifiée.
  1. Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool. Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool.
    • Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool.
  2. Remove the 10 7.1 mm screws using Phillips #1 screwdriver. Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Loosen the back cover by using a plastic opening tool all the way around the device.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
  5. Remove the back cover by gently lifting up on one side of the device. The easiest side to lift up on is the one with the removed rubber foot pads.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
Jillian Thomas
Membre depuis le 14/10/2017
189 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G121, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 103
