Aller au contenu principal
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
Ce dont vous avez besoin
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: étape 1, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 2, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 2, image 2 de 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 3, image 1 de 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 4, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 4, image 2 de 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Battery: étape 5, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Battery: étape 5, image 2 de 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 6, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 6, image 2 de 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 7, image 1 de 3 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 7, image 2 de 3 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 7, image 3 de 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 8, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 8, image 2 de 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: étape 9, image 1 de 1
    • Location of the SSD card
  10. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 10, image 1 de 1
    • Remove the Phillips 3.6 mm screw using a Phillips #1 screwdriver.
  11. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 11, image 1 de 1
    • Remove the yellow tape by slowly peeling it away at the bottom on the SSD.
  12. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 12, image 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: étape 12, image 2 de 2
    • Remove the SSD card from the motherboard by gently pulling up on the side where the screw originally was and out in the same direction.
Jillian Thomas
Membre depuis le 10/14/17
209 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G121, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 40
Total : 3,762
