Introduction
In this guide we will be dissembling the device so that we can replace the fan in the laptop.
Make sure the device is off to prevent data loss.
  • Make sure the device is off to prevent data loss.
  • Slide both latches to the unlocked position to release the battery.
  • Switch the latch on the right to reveal red. The latch on the left needs to be held.
  • Pull the battery toward you while holding the left latch.
Ajouter un commentaire
Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
There is also a small screw between the Display D-Port and USB on the side.
Graham Smith - Réponse
  • Pull up on the back casing and remove it.
There is also a flat flex cable for the PCMCIA card port that has a flick up press connector that needs detaching prior to removal.
  • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  • Disconnect the fan's power connector using the rounded handle plastic opening tool.
  • The fan should now be free of the laptop and can be removed.
JRJones
Membre depuis le 19/04/2013
121 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-19, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 membres
5 tutoriels rédigés
Don't forget the silver compound when re-assembling
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 2,793
