Introduction
Ce tutoriel vous montrera comment remplacer la batterie du Toshiba Portege Z835-P330.
Ce dont vous avez besoin
Retirez les treize vis de 1,4 mm au dos de l’appareil à l’aide d’un tournevis cruciforme n° 2.
Pour remonter votre appareil, suivez ces instructions dans l’ordre inverse.
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Brendan nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
6 commentaires
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Could anyone please tell me which type of screws are these ?
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
