Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
Ajouter un commentaire
Locate hidden screw found in the middle of back hardcover.
  • Locate hidden screw found in the middle of back hardcover.
    • Here you will find a proprietary Japanese Screw Head.
    • Remove screw by using tool not provided by IFixit or by using the methods found here.
  • Peel off hard cover to expose interior of device
  • Remove the two 1 mm screws using a Phillips #2 screwdriver.
  • Unplug the internal cooling fan by tugging gently on the wire attatched to the device's motherboard
  • Lift the internal cooling fan to remove the fan from the device
Dominic Whiting
Membre depuis le 08/02/2018
761 Réputation
5 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 65
