Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide gives instructions on how to remove the disc drive of the Toshiba SD-K740 DVD player.
Pièces
Aucune pièce spécifiée.
  1. Unplug the DVD player before beginning.
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Turn the DVD player on its side. Remove the 7.7 mm screw.
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Flip the DVD player over onto its front face.
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Flip the DVD player so its top is sitting on your working surface.
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away each of the two tabs located in the middle of the player.
    • The front panel will not come off during this step, so do not force it.
  5. Flip the DVD player on its side.
    • Flip the DVD player on its side.
    • Lift and slide forward a single tab on the side.
  6. Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
    • Grasp the front panel and pull forward and to your right to remove.
  7. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
  8. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
  9. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
  10. Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
    • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
  11. Lift disc drive vertically to remove.
    • Lift disc drive vertically to remove.
Joe Murphy
Membre depuis le 20/01/2011
542 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-16, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 22
Total : 2,445
