Aller au contenu principal
Toshiba Satellite 1805-S177 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: étape 2, image 1 de 3 Toshiba Satellite 1805-S177 Keyboard Replacement: étape 2, image 2 de 3 Toshiba Satellite 1805-S177 Keyboard Replacement: étape 2, image 3 de 3
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: étape 3, image 1 de 1
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite 1805-S177 Keyboard Replacement: étape 4, image 2 de 2
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
Hannah
Membre depuis le 06/24/10
227 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-5, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 membres
24 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,660
