Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
For the individual who constantly needs to run lots of programs at once, RAM that comes with a laptop often isn't enough. This guide shows you how to replace RAM that is either too small or gone bad.
Pièces
Aucune pièce spécifiée.
  1. Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator. Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator.
    • Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator.
  2. Using a flathead screwdriver or a shiv, insert the flathead of the screwdriver in the space between the plastic piece and the rest of the laptop. Pry the plastic piece off by moving the flathead screwdriver up and down.
    • Using a flathead screwdriver or a shiv, insert the flathead of the screwdriver in the space between the plastic piece and the rest of the laptop. Pry the plastic piece off by moving the flathead screwdriver up and down.
  3. Using your fingers, push two shorter sides of RAM away from each other. Note: The RAM should pop up automatically. Note: The RAM should pop up automatically.
    • Using your fingers, push two shorter sides of RAM away from each other.
    • Note: The RAM should pop up automatically.
  4. Using your fingers, pull RAM out of the laptop by gentling lifting up. When reinstalling ram be sure to line up  the ram correctly with the slot and notch in the ram
    • Using your fingers, pull RAM out of the laptop by gentling lifting up.
    • When reinstalling ram be sure to line up the ram correctly with the slot and notch in the ram
4 autre(s) ont terminé cette réparation.
Hannah
Membre depuis le 24/06/2010
209 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-5, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,581
