Ce dont vous avez besoin
First, slide the latch until you hit resistance. At this point, you have two options.
You can either keep pushing the latch until the battery pops out. . .
or you can start prying the battery out while pushing the latch (as shown in the second picture above).
Just lift the battery up and out, making sure to lift from the end near the latch.
Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
Outil utilisé dans cette étape :Tweezers$4.99
Unscrew the front of the casing by unscrewing the two 8mm screws indicated. We will be using a PH00 screwdriver for every screw in this guide.
You may or may not have to take the screw covers off beforehand. They’re easy to remove; all you have to do is pry them off. We used tweezers, but anything thin enough should work. Then, just unscrew the underlying screws.
To remove the cover, insert the spudger between the screen and the casing.
Start near the screws you just freed and work your way around the monitor.
To finish removing the cover, grab the corners near the hinges and gently lift out, up, and away from the hinges.
To disconnect the monitor itself from the bottom part of the laptop, remove the two indicated 8mm screws (on the sides of the hinges).
The next step to liberating your monitor is to unscrew the 6 screws holding it into its housing. These screws are only 3mm.
There will be three going up along each side.
Now here’s one of the trickier parts. You have to remove the pink and white cables that are connected to and from below the green chip.
We used tweezers(as shown).
Place the tweezers in the notch at the end of the white piece of plastic and pull it out.
It’s also tricky to put back in. Make sure that the pink wire is positioned toward the top of the laptop.
Lift the monitor until it’s positioned so that you can see the cable that it's connected to, for example as in the picture.
This step is easy, but be gentle. First, peel back the yellow anti-static tape.
Now, gently pull the connector away from the chip as shown.
Done! The monitor is fully disconnected from the laptop!
