Aller au contenu principal
Introduction
This guide will help you take out the battery, and replace it with a new one. Changing the battery is easy and simple.
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite A105-S4011 Battery Replacement, Battery: étape 1, image 2 de 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite A105-S4011 Battery Replacement: étape 2, image 2 de 2
    • Hold the release switch and pull out the battery towards you.
6 autres ont terminé cette réparation.
Lucas Salisbury
Membre depuis le 18/04/2013
73 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-14, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 membres
10 tutoriels rédigés
2 commentaires
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - Réponse
The part number is PSUB2U-00K00P
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 1,124
