Introduction
After diagnosing your Toshiba Satellite A105-S4074, should hard drive failure be imminent and replacement necessary, these easy to follow instructions will guide you through the process.
Ce dont vous avez besoin
Turn the laptop around so that the battery slot is facing away from you, and locate the hard drive access panel in the lower left-hand corner.
Locate the hard drive access panel in the lower left-hand corner on the bottom of the laptop, and loosen the 4.0 mm screw in the top center of the panel using the Phillips #1 screwdriver.
Carefully remove the panel with your fingers by lifting the edge at the indent.
To reassemble your device after replacing the hard drive, follow these instructions in reverse order.
