Introduction
The display is incorporated into the Lid of the laptop and is susceptible to cracking from falls or pressure. Often this could result in the laptop being unusable. This guide will show you how to disconnect and remove the Lid from the main laptop body, separate the LCD from the lid.
Pièces
Aucune pièce nécessaire.
  1. Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker. Use the plastic opening tool to pop off tabs along the length of this panel. This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  5. Lift the keyboard gently from the side closest the screen. Pull out the ribbon connecting the keyboard to the laptop. Pull out the ribbon connecting the keyboard to the laptop.
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  6. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  7. Remove the black and white wires. they simply lift off the posts. Remove the cable attaching the LCD to the motherboard, on the left side of the laptop. Remove the cable attaching the LCD to the motherboard, on the left side of the laptop.
    • Remove the black and white wires. they simply lift off the posts.
    • Remove the cable attaching the LCD to the motherboard, on the left side of the laptop.
  8. Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers. Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers.
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  9. Peel off the rubber circles from the  four corners. Remove the four 4.0mm phillips screws. Remove the four 4.0mm phillips screws.
    • Peel off the rubber circles from the four corners.
    • Remove the four 4.0mm phillips screws.
  10. Using the plastic prying tools separate the plastic surrounding the screen Lift out the broken LCD to be replaced. Lift out the broken LCD to be replaced.
    • Using the plastic prying tools separate the plastic surrounding the screen
    • Lift out the broken LCD to be replaced.
Josh
Membre depuis le 12/03/2014
610 Réputation
5 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 15
Total : 1,371
