Introduction
This guide will help you replace Toshiba Satellite A105-S4284 RAM. RAM allows memory to be accessed directly in a random order. You might need to replace a RAM if your computer shuts down abruptly, your computer performance is low quality, or the computer fails to install new programs.
Ce dont vous avez besoin
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
Un commentaire
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
