Introduction
If you have a compatible motherboard, a USB 3.0 port will greatly increase read and write speeds when using a USB stick to access saved files. This guide will show you how to remove your old USB 2.0 cable to make room for your new USB 3.0 cable.
Ce dont vous avez besoin
Locate the two sliding locks indicated in the photo.
Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
Slide the left lock (labeled "2") to the left and hold it in place.
Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
Locate the screws that are shown in the image.
Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
