Aller au contenu principal
Toshiba Satellite A215 S4697 Optical Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: étape 1, image 3 de 3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 2, image 3 de 3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: étape 3, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: étape 3, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: étape 3, image 3 de 3
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  4. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 4, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 4, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  5. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 5, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 5, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 5, image 3 de 3
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  6. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 6, image 2 de 2
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  7. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 7, image 1 de 2 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 7, image 2 de 2
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  8. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 8, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 8, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 8, image 3 de 3
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  9. Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 9, image 1 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 9, image 2 de 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: étape 9, image 3 de 3
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
9 autres ont terminé cette réparation.
Mike Dongyub Ryu
Membre depuis le 04/16/13
566 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-12, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 4,374
