Pièces
Aucune pièce nécessaire.
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from computer.
  • Failure to unplug the cable could result in electric shock.
  • Flip the computer upside down.
Ajouter un commentaire
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
  • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
  • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  • Gently lift and pull the battery out of the device.
  • Locate the RAM vented plastic cover in the center of the device.
  • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  • Locate 2 metal pinchers on either side of the 1st RAM stick.
  • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
  • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
  • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  • To remove the 2nd RAM stick, repeat previous steps.
  • You will be unable to remove 2nd RAM stick if the first one is not removed first.
Marianne
Membre depuis le 08/09/2014
647 Réputation
6 tutoriels rédigés
Équipe
Pasco Hernando, Team 5-2, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 167
