Aller au contenu principal
Toshiba Satellite A215-S7425 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite A215-S7425 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 RAM Replacement: étape 2, image 1 de 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 RAM Replacement: étape 3, image 1 de 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 RAM Replacement, RAM: étape 4, image 1 de 1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 RAM Replacement: étape 5, image 1 de 2 Toshiba Satellite A215-S7425 RAM Replacement: étape 5, image 2 de 2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 RAM Replacement: étape 6, image 1 de 3 Toshiba Satellite A215-S7425 RAM Replacement: étape 6, image 2 de 3 Toshiba Satellite A215-S7425 RAM Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 RAM Replacement: étape 7, image 1 de 3 Toshiba Satellite A215-S7425 RAM Replacement: étape 7, image 2 de 3 Toshiba Satellite A215-S7425 RAM Replacement: étape 7, image 3 de 3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
Marianne
Membre depuis le 09/08/14
647 Réputation
6 tutoriels rédigés
Équipe
Pasco Hernando, Team 5-2, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 23
Total : 321
