Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to replace or install the disc drive in your Toshiba laptop.
Pièces
Aucune pièce spécifiée.
  1. Power off the laptop.
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Slide the tab shown to the left and remain holding it. This tab does not lock into place like in the first step.
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  5. Flip the laptop over and orient it so that the battery faces away from you. Remove the 5mm Phillips #0 screw on the bottom case.
    • Flip the laptop over and orient it so that the battery faces away from you.
    • Remove the 5mm Phillips #0 screw on the bottom case.
  6. Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive. Slid the disc drive out of its slot on the left side of the computer. It should slide out easily. Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
    • Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive.
    • Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
Alana
Membre depuis le 14/04/2013
96 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-38, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 386
