Aller au contenu principal
Introduction
This guide will show you how to replace the keyboard on your Toshiba Satellite C55-A5100.
Pièces
Aucune pièce spécifiée.
  1. Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Lift the battery upward with your fingers out of the battery compartment.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached  to the keyboard.
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  5. Looking at the keyboard, locate the eight clips that hold it in place.
    • Looking at the keyboard, locate the eight clips that hold it in place.
  6. Use the plastic opening tool to slide the clips back, releasing the keyboard. As you release the clips, use the plastic opening tool to lift keyboard above the clips.
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  7. Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  8. Using your fingers, slowly pull the wire out of its connection.
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
Walker Tortorigi
Membre depuis le 29/01/2018
468 Réputation
4 tutoriels rédigés
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 182
