Aller au contenu principal
Introduction
Use this guide to remove the fan from your Toshiba Satellite C55-B5302 laptop. You will need a #0 and #00 Phillips screwdriver and a plastic pry tool. Make sure your laptop is unplugged and cool before you start. The fan is easy to remove and should take 10 to 20 minutes.
  1. Flip laptop upside down so you can see the screws. Flip laptop upside down so you can see the screws.
    • Flip laptop upside down so you can see the screws.
  2. Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing. Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Pull the battery from the back of the laptop for removal from the laptop.
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver. Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off. Expect to hear popping as you pull the back panel off.
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Disconnect the fan wire from the motherboard.
    • Disconnect the fan wire from the motherboard.
  6. Remove the three  3 mm screws with a Phillips #00 screwdriver. Remove the 5 mm screw with a Phillips  #0 screwdriver. Remove the 5 mm screw with a Phillips  #0 screwdriver.
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. You can now lift the fan out of the laptop.
    • You can now lift the fan out of the laptop.
Jacob Mayes
Membre depuis le 04/10/2018
217 Réputation
2 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 82
