Aller au contenu principal
Toshiba Satellite C55-B5302 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Hard Drive Replacement: étape 2, image 1 de 2 Toshiba Satellite C55-B5302 Hard Drive Replacement: étape 2, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Hard Drive Replacement: étape 3, image 1 de 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Hard Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite C55-B5302 Hard Drive Replacement: étape 5, image 2 de 2
    • The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
  6. Toshiba Satellite C55-B5302 Hard Drive Replacement: étape 6, image 1 de 1
    • Gently pull the hard drive away from the connection to remove it from the laptop.
3 autres ont terminé cette réparation.
Jeff Sims
Membre depuis le 10/02/18
242 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,187
