Aller au contenu principal
Toshiba Satellite C55-B5302 Monitor Screen Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Battery: étape 1, image 2 de 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 2, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 2, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 3, image 1 de 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Fan: étape 4, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Fan: étape 4, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Fan: étape 4, image 3 de 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 5, image 1 de 1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 6, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 6, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 6, image 3 de 3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 7, image 1 de 1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Screen Bezel: étape 8, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Screen Bezel: étape 8, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Screen Bezel: étape 8, image 3 de 3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 9, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 9, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 9, image 3 de 3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 10, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 10, image 2 de 2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 11, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 11, image 2 de 2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 12, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 12, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 12, image 3 de 3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 13, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 13, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 13, image 3 de 3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 14, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 14, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 14, image 3 de 3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
  15. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Webcam: étape 15, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Webcam: étape 15, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Webcam: étape 15, image 3 de 3
    • Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
  16. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 16, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 16, image 2 de 2
    • Remove the two 3.1 mm Phillips #0 screws at the top of the screen.
  17. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 17, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 17, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 17, image 3 de 3
    • Pull up on and turn over the screen to expose the wire connecting the webcam to the screen.
    • Be careful not to pull up on the screen too far and damage the wire.
  18. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 18, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 18, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 18, image 3 de 3
    • Once the screen has been detached and turned over, remove the webcam from its place on the bezel.
  19. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 19, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 19, image 2 de 2
    Outil utilisé dans cette étape :
    • Carefully, take off the tape connecting the webcam to the circuit board using a set of tweezers.
    • Once the tape has been removed, you can disconnect the webcam from the wire completely.
  20. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Monitor Screen: étape 20, image 1 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Monitor Screen: étape 20, image 2 de 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Monitor Screen: étape 20, image 3 de 3
    • Have the screen along with the metal hinges stand upright on one side.
    • Remove the three 3 mm Phillips #0 screws from the metal frame attached to the hinge.
    • Separate the metal frame from the rest of the screen.
  21. Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 21, image 1 de 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: étape 21, image 2 de 2
    • Repeat the previous steps to separate the metal frame on the other side.
Ebin Daniel
Membre depuis le 03/25/19
109 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G3, Henning Spring 2019 Membre de l'équipe IUPUI, Team S1-G3, Henning Spring 2019
IUPUI-HENNING-S19S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 579
