Aller au contenu principal
Toshiba Satellite C55-a5310 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: étape 2, image 1 de 2 Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: étape 2, image 2 de 2
    • Remove this screw with a JIS #000 screwdriver.
    • This screw does not come out all the way.
  3. Toshiba Satellite C55-a5310 Keyboard Replacement: étape 3, image 1 de 1
    • Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
  4. Toshiba Satellite C55-a5310 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite C55-a5310 Keyboard Replacement: étape 4, image 2 de 2
    • Using the JIS #000 screwdriver, remove the .5mm screw.
  5. Toshiba Satellite C55-a5310 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite C55-a5310 Keyboard Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to remove the keyboard from the laptop.
  6. Toshiba Satellite C55-a5310 Keyboard Replacement: étape 6, image 1 de 2 Toshiba Satellite C55-a5310 Keyboard Replacement: étape 6, image 2 de 2
    • Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
3 autres ont terminé cette réparation.
Kari Rodgers
Membre depuis le 02/08/18
482 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team S16-G1, Nardone Spring 2018 Membre de l'équipe Sam Houston State, Team S16-G1, Nardone Spring 2018
SHSU-NARDONE-S18S16G1
5 membres
15 tutoriels rédigés
2 commentaires
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Anthony Francisco - Réponse
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
Jeff Breuer -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 2,236
