Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
  1. Push the left tab with your left hand. Then push the right tab with your right hand. While your right hand is still pushing, remove the battery with your left hand.
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Remove this screw with a JIS #000 screwdriver. This screw does not come out all the way.
    • Remove this screw with a JIS #000 screwdriver.
    • This screw does not come out all the way.
  3. Essential Electronics Toolkit
    Petit kit. Grandes possibilités.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
    • Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
  5. Using the JIS #000 screwdriver, remove the .5mm screw. Using the JIS #000 screwdriver, remove the .5mm screw.
    • Using the JIS #000 screwdriver, remove the .5mm screw.
  6. Use the plastic opening tool to remove the keyboard from the laptop. Use the plastic opening tool to remove the keyboard from the laptop.
    • Use the plastic opening tool to remove the keyboard from the laptop.
  7. Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop. Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
    • Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
3 autre(s) ont terminé cette réparation.
Kari Rodgers
Membre depuis le 08/02/2018
482 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team S16-G1, Nardone Spring 2018 Membre de l'équipe Sam Houston State, Team S16-G1, Nardone Spring 2018
SHSU-NARDONE-S18S16G1
5 membres
5 tutoriels rédigés
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Anthony Francisco - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 61
Total : 1,163
