Aller au contenu principal
Toshiba Satellite C55D-A5108 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: étape 2, image 1 de 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: étape 3, image 1 de 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: étape 4, image 1 de 2 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: étape 5, image 1 de 1
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: étape 6, image 1 de 2 Toshiba Satellite C55D-A5108 Keyboard Replacement: étape 6, image 2 de 2
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
Michael Medeiros
Membre depuis le 10/25/19
150 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 286
