Aller au contenu principal
Toshiba Satellite C55D-A5108 RAM Stick Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55D-A5108 RAM Stick Replacement, Battery: étape 1, image 1 de 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 RAM Stick Replacement: étape 2, image 1 de 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 RAM Stick Replacement: étape 3, image 1 de 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 RAM Stick Replacement, RAM Stick: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the memory cover.
  5. Toshiba Satellite C55D-A5108 RAM Stick Replacement: étape 5, image 1 de 1
    • Carefully hold the edges of the RAM and remove the stick.
  6. Toshiba Satellite C55D-A5108 RAM Stick Replacement: étape 6, image 1 de 1
    • Line up the new stick of RAM with the gold contacts facing the slot and evenly push the new stick into the same slot which you removed the old stick.
Geoffrey Souza
Membre depuis le 10/25/19
327 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 11
Total : 317
