Aller au contenu principal
Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: étape 6, image 1 de 3 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: étape 6, image 2 de 3 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: étape 6, image 3 de 3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: étape 7, image 1 de 2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: étape 7, image 2 de 2
    • Remove the single screw securing the Wi-Fi card using a Phillips #0 screwdriver.
  8. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: étape 8, image 1 de 2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: étape 8, image 2 de 2
    • The card will pop up; gently pull the card out of the port.
    • Unplug the wireless antenna cables attached to the card.
    • Remember how the cables were connected to assure you do not cross the Bluetooth and wireless connections by accident.
Ryan Smith
Membre depuis le 10/25/19
187 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 15
Total : 1,070
