Aller au contenu principal
Toshiba Satellite C55D-A5201 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 2, image 1 de 1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 3, image 2 de 2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: étape 4, image 1 de 2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 5, image 1 de 1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 6, image 1 de 1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 7, image 1 de 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 7, image 2 de 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 7, image 3 de 3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 8, image 1 de 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 8, image 2 de 2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 9, image 1 de 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 9, image 2 de 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 10, image 1 de 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: étape 10, image 2 de 2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
13 autres ont terminé cette réparation.
Kari Byrd
Membre depuis le 03/24/15
614 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 6-5, Shaver Spring 2015 Membre de l'équipe Baylor, Team 6-5, Shaver Spring 2015
BU-SHAVER-S15S6G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 5,877
